Looking for someone to design a mosaic
For several years now I've been wanting to make a large Lego logo mosaic (thinking like 4x4, or 192 studs by 192 studs). I've failed miserably at trying to come up with a design for it. Pic to Brick is WAY outside my comfort level from a technical standpoint, and I haven't found anything else usable (Photobricks on my iPhone didn't work well either). I'm looking for someone who could put together the layout for this, and send along a parts list and instructions. I will pay the person for this process. Anyone have any ideas about someone who could possibly do this? Thanks in advance for your help!
- Brickbuilder0937
- TnB Forum Moderator
Re: Looking for someone to design a mosaic
I made a LEGO logo a few years ago, a bit smaller though (144 wide), but you can use it if you want. There are a couple spots that may need touched up a bit around the edges.
You do not have the required permissions to view the files attached to this post.
Thanks so much for this! Is there a program to which I could download this to provide a parts list and the like?Brickbuilder0937 wrote:I made a LEGO logo a few years ago, a bit smaller though (144 wide), but you can use it if you want. There are a couple spots that may need touched up a bit around the edges.
- Brickbuilder0937
I had used a cross stitch program (called MacStitch) to make this.
The approximate number of studs in each color (not counting the black strips on the edges) are:
Red - 6,830
Yellow - 1,260
Black - 2,450
White - 3,090
Red - 6,830
Yellow - 1,260
Black - 2,450
White - 3,090
